We’re on a free plan and created too many items, which made the entire doc read-only. BUT, since it’s read only we can’t delete anything to get it under the limit. As far as I can tell, we’re permanently locked out. Anybody know how to get around this?
We literally created a blank tab on the left by accident and just need it removed . . .
There should be some grace period (7 or 14 days) before an overgrown doc gets locked, IIRC.
If it got locked sooner / the period has passed, you can try reaching out to support and ask them to delete something for you.
If anything else fails, try copying the doc — it will create a new doc with all the data but the grace period should restart, giving you the chance to slim the new doc down.
