I have a column that is a lookup to the same table (used to connect related rows).
I want to prevent accidentally referencing to self (same row).
So far I was able to filter by using _Item settings _ with formula name != thisRow.name but that filters out by name and if the names are duplicate it doesn’t allow select the related value.
Is there an option to actually filter the currentRow as a general item?
You can rely on a unique attribute - such as RowId() - so if you simply add a Row ID column containing RowId(thisRow) (also by easily selecting one of the Properties Columns as on the snapshot), then you can set the Item Settings like Row ID != thisRow.Row ID
