Hello! I’m partially color-blind but would still love to format my tables with color - being able to label “Finance” as green, etc.
Is it possible to add the name of the colors when hovering over these circles?
This was a fun challenge, I got a little working temporary solution for you
Off at the top (Make it On)span[aria-label]:hover:after {
position: fixed;
z-index: 1;
margin-top: 3em;
margin-left: 3em;
padding: 1em;
display: block;
content: attr(aria-label);
color: #fff;
background: #000;
opacity: 0.8;
pointer-events: none;
I found that the colors have an aria-label attribute already defined. No idea when they are actually used but here we are! All we’re doing is creating a text element when they are hovered
It’s a bit wonky if you scroll down on a sub-element, it also doesn’t seem to care about dark-mode, otherwise I think it works decently! Has a fun side-effect of giving other random toolbars too. Feel free to play around with the values in the css
Hi, @Brian_Yip!
We recently added tooltips to our color pickers to show the color names on hover. We hope this helps!
