I am a newbie here but I love how in Google Docs I can choose the color of my documents by putting in Hex Codes and dragging to certain colors. IM not fond of the fact that there are only 6 colors to choose from here on coda…
I would also live to add more colors to tables.
And since grammarly doesn’t work on here, you should integrate spell check!!!
Great decision to join the community, a warm welcome
Coda is a “makers tool” meaning that it’s fully booked with instruments to challenge you creativity. Everything is kept at a minimalist level when you speak about the user interface, but behind you can uncover so many and make something unique to your use case.
Concerning your question I recommend to check out the below for inspiration:
