Hey there!
I love beautiful docs and I love colors - theres nothing quite like a good color scheme to make your docs/website/materials look gorgeous!
Yes, there are many other websites on the internet that do similar things, but I always find Coda docs far easier to use than random websites with ads, or superfluous features. Let’s be honest, everything’s better in a doc.
I made this doc as a repository for colors I find myself often using in docs and elsewhere and thought I’d pass it along to the community.
- See the doc and copy it for yourself here → Colors Doc
Or keep reading on to see the main pieces of the document:
All Colors
The doc has over 900 colors categorized by Hex Code and RGB Code with included search bar and quick sort to find main colors.
Color Palettes
I’ve created 27 easy to use color palettes with corresponding hex codes (use in a doc or outside your doc!)
RGB Color Chooser
Want to create your own custom colors? The doc includes an easy to use RGB Color Slider that shows you the corresponding hex code, the color itself, and then how your color would look as text on both white and black backgrounds
