Stacked images with button formula
Hello Codans,
how can I programmatically obtain the effect of stock image files? I would like to achieve an effect like the one shown in the screenshot (created by dragging several files into a column). The thing is that I need to upload several covers from a table, using a button and so far I haven’t found the way to get such results.
Hello @Pawel_Polanski
I’m afraid that’s not possible.
The only workaround I can think of at the moment is to use a button with the image you want and utilize the Badge feature inside the button:
Perhaps other makers might have a more clever workaround.
Best Regards
Arnhold
Edit: I don’t think it’s possible with this pack. It’s a feature request…
Hi, @Pawel_Polanski .
Have you tried this pack bellow?
Hey Pawel!
Your question has been in the back of my mind, working on an unrelated project I realized I have a solution for you :clap:
:gem: Elegant! In fact, this solution is about more than just stacking images. This technique can be used to automatically generate a training slideshow based on specific data.
