Tables > 125 mo. Alternatives
Hello,
In Coda, once a doc/table exceeds 125 MB, it’s no longer possible to use cross-doc or the API.
I’m looking for a solution to handle tables larger than 125 MB and to display/edit their data in Coda.
Do you know of any solutions that would allow me to dynamically display excerpts from such a table—hosted, for example, in a PostgreSQL database—or any alternative approach?
thanks !
Have you thought about using xano or Supabase?
Both of which have two-way sync packs for Coda?
Hi Scott
Thanks, I will check this out :grinning_face:
