Hi, I am trying to create a simple app but most likely I think in the ”excel” way and not the ”coda” way and therefore I am not able to get this to work. I am new to coda so bare with me…
I have three tables where the main one handels transactions. For each transaction I have to select a company which is in another table. This I have solved and I have a dropdown in the first column of the transaction table that allows me to select the company.
In the second column of the transaction table I would like to be able to select only the types of transactions that are applicable for that company. I have a third table which has a the name of the company in the first column and the transaction type in the second. A company can have multiple entries in this table.
In ”pseudo code” I would like to:
SELECT investment_type from tbl_transaction_types WHERE company = ”tbl_transactions.company”
Looked at the recipe example but that does not create a dropdown, only lists the ingredients with a comma inbetween.
Thanks
Hi @Erik_Markman,
you can have filtered lookup based on another column selection.
Have a look at this minimal sample:
As you can see, in the Transaction lookup, if you open the Item setting section you see the filter related to the Company column.
I hope this helps.
Cheers!
Thanks @Federico.Stefanato !
I managed to get it to work but I am not 100% sure I fully understand the filter. How should I interpret it? CurrentValue is the alternative (A, B, C etc) from the table you do the lookup against and that is compared to what’s in the company table, allowed transactions column? Did I understand it correctly?
Thanks again!
Hi @Erik_Markman,
CurrentValue is widely used in formulas and is quintessential in the Coda’s conceptual model.
Its practical meaning can vary a bit in the contexts but you’ll get soon familiar with it.
In this use case, CurrentValue represents a way to refer to the lookup list itself.
If we could instruct the column settings in plain English, it would be:
- "Hi Column, I wish you’d be a
Transaction" (Select Column Type)
- “Therefore I can select from the list of all Transactions” (implicit lookup on the
Transaction Table)
- “Of all those transactions, please be only the ones that the Company (your sibling column) tells it might have” (
CurrentValue here is the be…)
I don’t know if I clarified the concept or just the opposite, but I hope it helps
Cheers!
I appreciate the simplified explanation.
Best regards
Erik
