I am experimenting with the new custom domains feature and noticing that my various URLs end with a - and a number. Where does that number come from? Is that editable? If it increments, what does that mean for bookmarking.
I was also looking at the samples provided by Coda and seeing similar behavior.
Hey @Colleen_Brady! That’s the expected behavior for child pages in published docs. The number uniquely identifies the page, and it exists so that if you rename a page, any existing link will continue to work indefinitely. Coda controls the numbering on your behalf, so it’s not configurable on your end.
