Good Morning Coda Community , first allow me to thank you for this great wonderful app I really like it.
I am Facing an issue Regard filter formula I have table and i want to filter one of the column but the thing is that its not show up as unique value in filter its grouping all rows as its not filter what should i do
just like that
Double checking first, but is your goal to filter by phase (e.g Phase 1, Phase 2, Phase 3)? If that’s the case then you would need another column. Maybe call it Phase with the values “Phase 1, Phase 2, Phase 3”. Then you can create another filter and it should only show 3 items.
Right now all your phase descriptions are different so the filter will have an option for each phrase description.
