- Is it possible to share a specific page with my team on Coda.io, but restrict their access to certain filters? [[1]]
- Can I centralize the contacts of each team on Coda.io, without allowing Team 1 to see records from Team 2? [[4]]
I Don’t know if chatgpt is right:
Coda.io is a document collaboration platform that allows users to create and share interactive documents. Users can create pages with various building blocks, such as tables, charts, and buttons, to build interactive and customizable documents. Coda.io also provides features for sharing documents with others, such as commenting rights, publishing pages, and using Cross-doc to share data across different documents. [[1],[4]]
Regarding the first question, Coda.io allows users to share specific pages with their team members and set different access levels for each member. Users can restrict their team members’ access to certain parts of a page, including filters, by using the “Access Controls” feature. This feature allows users to set specific permissions for each team member or group, including view, edit, or comment. By setting the access controls, users can ensure that their team members can only access the parts of the page that are relevant to their work. [[1]]
Regarding the second question, Coda.io allows users to centralize contacts from different teams in one document and use filters to control access to specific records. Users can create a table that contains all the contacts from each team, and then use filters to control who can see specific records. For example, users can create a filter that only shows records that belong to Team 1 and grant access to Team 1 members. Similarly, users can create filters for other teams and grant access accordingly. By using filters and access controls, users can ensure that each team can access the contacts they need without seeing records from other teams. [[4]]
