Thank you for your reply @Denis_Peshekhonov. The problem with that solution is that Slack would not provide an easy way to input information for the table.
This is what I see when I create a task in Asana directly from Slack. It would be nice to have similar functionality for Coda as well:
100% second this. I think the Slack integration should be all about creating items in Coda from Slack, in a similar for to what @Raul_San_N.H you are suggesting. Most project management apps have integrated well with Slack at this point. Ideally, I’d like to be able to even have a small comment or footer in the description of the row in Coda saying “coming from Slack” and a link added back to the original Slack convo. I assume the Product Team will set this up soon as I am not aware of practically any app out there that does not have this basic connection with Slack, the ability to create an item in the app directly out of a Slack convo.
This is interesting… I guess you’d first have to select the doc, then the table, then it would dynamically show you inputs based on the table? Seems a bit cumbersome, though maybe you could favourite some tables or something
