Something involving a character and a number combination (ORG vs ORG19) in the middle of the sku makes the sort misbehave. I tried some testing, but simpler use cases seem ok.
Quickest Summary: If we have thing_1 and thing1_1, Coda sorts them in the Wrong Order.
Something about number_number messes it up.
Here’s a doc to play:
Let’s see if this helps drive the point home
I didn’t feel a doc would be useful as this is not a document specific issue. I am not troubleshooting a doc… I am raising a coda-wide possible that seems to be large that I don’t even understand.
Also, the issue is only visible when you compare the behavior to other systems (Sheets, Excel…), which is why I thought screeshots comparing the behavior were the way to go.
