For all the non-coders and Coda beginners:
You do not have to write code, not even a little bit of code, to create a valuable tool in Coda.
I am in the process of creating a document that can be used in the implementation of SAP to assist in the gathering of user requirements, master data information, the resulting configuration settings to be made and the documentation of all of the aforementioned. The document will also manage and record the meetings and resulting action items involved in the whole process.
WITHOUT A SINGLE LINE OF CODE.
I have just used lookups between tables, and two packs. The two packs are the Gmail pack, and the Doc Explorer pack created by @Scott_Collier-Weir.
Here is a video explaining the doc:
(25 minutes - listen at double speed!)
I tried to keep the explanation as short as possible. But there is a LOT happening in the doc, and even a very high level overview is going to take some time.
Which just goes to show the powerful no-code tool which is Coda.
And the current iteration of the implementation document is here:
Regards
Rambling Pete
