In this section: Coda API (v1) Reference Documentation, in the example given for rich valueFormat, the objects in the snippet have a type property, which is not what is expected from JSON-LD syntax (which expects a @type), and differs from the actual response received when calling this API endpoint (also @type)
Good catch! I’ll update the documentation to reflect the actual behavior.
