Coda:
need 2 steps to set collapse head 1, 2.
Others:
Automatic set collapse.
We always need collapse Head
Coda:
Others:
Not a deal breaker for me. However based on the behavior I have seen in βotherβ platforms, it would be good to see a feature like, if you just hit enter after completing the heading, then that keeps the heading collapsed and takes you to the next line, but if you hit βctrl + enterβ it takes you inside the expanded heading
Yes. Both are good features, Thanks @Jaisil_Muttakulath_Joy supplements.
hit Enter go to next Head 1 and keep head collapsed.
and hit ctrl + Enter go to inside the expanded heading.
