Hello,
when I try to log in to Coda using the 1password autofill in Firefox or Chrome, it does not work for me. The fields just do not get filled. I have to manually copy and paste it from my password manager.
Do other people also get this problem?
Reproduction:
Just log out of Coda, have the 1password extension installed, and try to click the autofill button. The fields are not populated.
Best
Aaron
PS: I think this is a bug of Coda and not 1password since it works on all other platforms/wesites. And it has not been working on Coda for weeks.
Dear @AaronOnCoda ,
Just a quick reply from my mobile device.
Please check if auto fill is switched on at the column applicable. Coda has an option to switch off auto fill
I also think that by default it’s set to off now
Hey everyone!
I don’t think that @AaronOnCoda is referring to any auto-fill features inside of Coda, but rather the ability for 1password to autofill a saved password in order to log in to Coda on this front screen
I can’t speak to whether its a bug or not as I don’t personally use 1password but you could reach out to Coda support so they can check into it further! Sorry I couldn’t help more
