The automation triggers only if the IsNewRow checkbox changes, which is only upon creation (because it is automatically filled upon creation and later this column is never used, so it never changes any more). It is advisable to hide this column, because it prevents mistakes (and for the automation it makes no difference).
Don’t forget to turn on your automation once you are done
Success,
Greetings, Joost
