Hello,
I am new here and trying to do some basic math across some tables.
I have the current formula
The first number is in another column on the same table
The other two columns are from lookup columns, which are currently showing the number that i want to add (i.e., display column from the table that i got)
I get the wrong sum value when I have the three numbers on the formula. However, if I use only two of them, I get the right number.
