I keep noticing that certain default settings in Coda make no sense in terms of data security and are sometimes almost negligent. For example, the default setting for sharing a doc is that all editors of a document can change the access rights and publication settings themselves. This makes no sense and should be deactivated by default!
In addition, this point, like the other point I mentioned in another thread, can only be viewed through a submenu; when a Doc Maker shares a document, he does not assume that editors can also administer the rights, because in almost every case the docmaker wants to have the power over permission-rights. Please adjust this!
