I have a question about how to get a calendar view to update to a filtered month. I have a document to track marketing emailers. To keep the table from getting out of hand, ever entry to the table has a hidden field set with the month number. That way I can have a dropdown menu to pick the month and only those emails show up on the calendar (or any other table view) when selected. The problem I have is that when I filter emails for October, the calendar is showing September (with no data). How can I get the calendar to update to show the filtered month? Is it possible?
The reason that they are not working together, is because they are controlled by two different controller - the red and the blue respectively.
Unfortunately I am not aware of a method to link the two controllers, with the problem being I don’t know how to get hold of the blue controller in the calendar.
Hopefully one of the people that knows Coda internal workings better can help out here - if we could control the blue controller using the same info as the red controller, they would synchronise.
Navigating the month in the calendar view and filtering data in the view are 2 different things.
I think this will answer your question: When you filter the data, only data that’s filtered will show up but you can still navigate to any month you’d like.
I use the table view in other places (and it works) but visually it’s easier to understand what is happening on each day of the month to see it in the calendar view.
