Calendar with images
Hi there – does anyone have a solution for a visual calendar display, such as with images showing for each day? Currently I have an image column as a display column, and it looks like this. The images are super tiny and unappealing with the squares around them. I’d love for the image to be the full size of the calendar square or otherwise more visually appealing.
Is there a way to do this – perhaps with a pack? Thanks!
In case anyone is coming back to this post – I haven’t figured out a solution within the “calendar” view. What I ended up doing is a Card view grouped by weekday to simulate a calendar.
Looks like this:
Here’s the doc: Visual No Buy Tracker
If you use this, note that one workaround I had to add was to create a card for every day starting with the Sunday prior to the actual start-date I wanted, or else the cards are not aligned horizontally in the correct week. See the “create my no-buy calendar” button.
Improvements to this solution welcome if you have ideas for a better visual.
Hey @KatyStalcup! Thanks for reaching out. While this is not possible at this time, this sounds like a feature request the Coda team has been tracking to have more customization for Calendar view. That said, we have moved this post into the Suggestion Box for other members of the Community to chime in on this. We’ve gone ahead and tracked your vote for this feature formally.
