This is an old bug and I thought it would have been fixed by now, but I can’t even find a posting about it, so here it is:
In calenderview, an event that spans multiple days, does not show up in the right hand column, like this:
I think it has to be with how you have set up your working days
Hello @Jafet_Mtz ,
Can you show me a correct view of a similar calendar with what you thing is the correct setup of your working days? I understand what you are saying, but I don’t know how to fix it.
Greetings, Joost
Hello, I couldn’t replicate the situation, but try if something works going in the tablo to Options> Calendar Display> Respect working days and Date settings
Hey @Jafet_Mtz ,
If you can’t replicate, you can show me an example calendar view without the gaps? I don’t understand what is else I can change to make this work.
Greetings, Joost
Any calendar table, regardless of time zone, setting of workdays, date format…I have changed every thinkable parameter on the doc level and on the table level - to no avail:
The only thing I don’t want to change it the time zone for my entire account - to risky for all my docs (all based in European time zone).
Here is a not protected calendar in my doc area. I would love for someone to show me how to make this look the way it should.
Edit: doc. deleted
Coda has confirmed this as a bug in some timezones.
I have deleted the sample doc - it does not serve a purpose any longer.
It is unknown how long it will take to fix this bug.
