Hi, I’m trying to get a detail layout (for a line from a Coda table) to print nicely on A4. (I’m using the Coda table to capture details of a purchase order, but need to send the actual PO, on company letterhead, to the supplier). I’ve added a hidden image column to the table and I can set a default image for that to that this works as the letterhead - all fine. But I can’t work out what size image I need to upload! I’ve tried quite a few sizes and they all seem to resize - so the letterhead overhangs the detail page. Is there a correct size? Or a better way of doing this?
Thanks, T
