Can we display negative numbers & percents in brackets?
Hi everyone,
Is there any quick solution to format negative numbers in brackets (accounting number format)?
Thanks for your help.
Yes! You can use Accounting format for a currency value or column.
Thanks @Hector_Reyes1 ! Realized I should have specified but I was hoping to do this for a Percent column, which doesn’t show the option to select “Accounting”
