Even can’t copy and paste powers of 2 .
I don’t need calculate powers of 2 , just input .
LaTeX::Math(Format(“{2}^{2}”))
Thanks. Got it .
But need more steps.
FYI to avoid confusion, the syntax is e.g. LaTeX::Math("2^{10}")
You pass the formula string. X^Y makes a superscript. Wrapping Y into curly braces {Y} makes sure that superscript is applied to all text in braces, otherwise it will only be one digit.
Format("{1}{2}", arg1, arg2)
is a different, unrelated formula just to make inserting values in a template string easier. Could’ve just used Concatenate or + instead.
LaTeX::Math("2^{" + Column2 + "}")
would’ve done the job just as well.
Thanks for tips.
Thanks for tips.
Thanks for tips.
