Changing Styles across a document
I want to update all my H1 headings to Dark Blue, Bold and H2 to Dark Blue, Not bold. How can apply changes to all existing H1 and H2 entries and set as default for all new entries
:waving_hand: @Philip_Milne
welcome to the community! :hugs:
unfortunately, there is no default theme function in a coda doc. Headers etc have to be set manually.
a tip to do this as quick as possible would be to turn on “Outline” in the Page options, then you can click on them to take you straight to it instead of scrolling up and down.
hope this helps!
Cheers!
Mel
like
Philip Milne reacted to your message:
