I’m trying to do quite a simple action. I have a table that plays a video when “PlayNow” checkbox is checked. To make it more useable, I’m trying to turn the PlayNow checkbox into a button, which is much more user friendly for this particular usecase.
Under Label for the button I have “If(thisRow.PlayNow,“Reset”,“Play”)”. This works perfectly.
However, I can’t seem to get the button to check/uncheck based on the button. The code I have under action is “If(thisRow.PlayNow, thisRow.PlayNow=false, thisRow.PlayNow=true)”
In theory, this should toggle the checkbox between checked and unchecked, but instead it does nothing. A link to the document is here: https://coda.io/d/Habit-Installer_dCozTbMijjn/_suspK
Any suggestions?
