I’m new to coda, i’m trying to understand basic stuff that I can do with sheets or excel, but something so simple in some programs looks IMPOSSIBLE to me after hours of trying. I just give up
Anyone can tell me what am I doing wrong? I don’t think i’m asking for something so over complicated.
I only want to multiply (product.1 * product.2 ) / 1000
Welcome to Coda!
Doing row-specific calculations isn’t ideal in Coda. It makes more sense to transpose your table in this case. Calculations are usually defined for entire columns!
Another option: if you need to get this type o % in a column and you do not find it in Summary, you can write a formula outside the table to summary. See an example in the image below:
