It re-sorts now when you change the data type but not for a linked chart.
Tell me how to share/send an example and I’ll show you.
The way to share a doc by going to your dashboard and selecting the three dots to the right of a Doc name.
You can share any examples you have with support@coda.io. Thanks!
Ah, I misunderstood, my bad.
Thanks for sharing your example. I realize now that you meant manually moving rows, not applying sorts to your current view, which is what I had assumed. I’ll have a fix out in the next build, probably hitting production on Monday.
Yes - manually moving rows, not sorting. The chart changes when switching between grid and chart mode but the linked one doesn’t. Thanks for the update.
A post was split to a new topic: How can I get a chart per single industry
