I can’t wait 15 minutes and try 5-6 times each time I want to sign in.
How can I force login id and password.
If they truly want to do 2-factor login, then they should do it right with TOTP.
Tired of this; any of you see this?
Hey @Lewis_Levin,
Dan here from support. Do you mind opening up a ticket with us in your doc, so we can take a closer look at this for you. It should not be taking this long to log into Coda. I’m concerned that there may be something else going on here. You can reach us by clicking the “?” in the lower right-hand side of the screen and then clicking “Get Support” at the bottom. Anyone of us here on support will be able to help take a look at this for you.
Looking forward to diving in on this one with you.
All my best,
Dan
