I would like to build a simple project and task database, where I can click on a project and see my tasks and notes for that project. Now my question is, if I have like 100 tasks, I always need to scroll down crazyli until I can access my Notes (see screenshot). Is it somehow possible to collabse my tasks? Or but them in a separate window where I can scroll?
Thank you!
yes, one way is to make them subitems.
hmmm, thank you, but not really. subitems then have the same columns like my project and not like my tasks, right?
You can create a toggle (in my example Show tasks) and only show your tasks if its true.
SwitchIf(thisRow.[Show tasks],[Tasks].Filter(Projects.Contains(thisRow)))
Yes the columns would be the same. But it doesn’t really matter, does it?
yes
I want to fill the columns for my task database and not for my project database
amazing, great, and this applies to all new projects then? ok, I think I need to familiarize myself bit better first with templates. Thanks a lot!
Yes of course.
The Tasks column is just a relation column that can be displayed as a table in the detail view.
You can define any logic to decide what gets displayed here and not. The formula from my previous message means: For each project, if the toggle is off don’t show anything, if it’s on show all the tasks that belong to the current project.
…and the a toggle column has some nice options when you hoover over the column title:
