Next to setting a title for a column, it would be great to be able to add a description field to each column.
In this you could set
- explanation for how to use this column (handy for multiple users)
- why you created a this column for future reference
- explanation of how your formula is set up (handy if you have to go back to it months later)
this would be viewable as a call-out
in google sheets you can add a comment to each field, so I use this in the title row
I’m looking for something similar
Now i need to write everything in the doc itself, or create long column titles (which is not handy in formulas)
