Hello and thanks for the help.
I have three documents:
- customer document 2.
- Document for tasks
- Document for a specific client
In the task document I have used cross doc to bring the customer table to link the task table with the customer table.
So far so good. But, when in the document for client A, for example, I use cross doc to bring the task table (from the task document) and I want to filter it to show only those of client A, the filter does not work. It comes out as follows:
Why is this happening, why is the filter not recognizing the records in the customer column?
Thank you very much for your help.
