Hi guys,
Not sure if a solution exists for this, but I am having trouble with thisRow type referencing for a lookup column subtable in expanded row layout views. As shown in my screen grab, I can use the canvas column to create a table and use the parentRow reference to provide conditional formatting for the current row. I can’t seem to find a way to achieve the same effect with the subtable of a lookup column in a layout view (called Related Projects in my screen grab). The screen grab probably illustrates my point more clearly.
Does any one know if it is possible to do this?
Cheers,
Michael.
