Configuring a Chart in a Modal
I finally found a good use case for displaying a relation column in a modal as a chart. The problem is, I can’t find a way to configure the chart. I need to find the configuration options to change chart type, data sets, colours, etc.
Has anyone experimented with this?
Just configure it like you would a normal chart - while viewing the table normally in your doc.
Exit out of that detail layout edit view
Thanks for your reply, Scott, but the Vote Results Chart is a relation column in another table. Closing the modal view just brings me back to the table, and I still don’t see where I can configure the chart.
Dont close the modal view, rather just don’t enter the modal EDIT view.
Just in the normal modal view of a row you should be able to configure relation columns as charts, etc.
Or maybe I’m misunderstanding the question?
This is it, not sure how I missed it. Thanks Scott!
