Count minutes using duration sty
hello, how do i construct a formula to add minutes in a column with ‘duration’ type? I am planning an event that will last one hour. I would like a running time so I know when I’ve reached an hour for each speaker and can adjust. How do I do that?
I got this far:
Screenshot 2023-03-01 at 2.26.38 PM
Hi Rosa,
Welcome to the community!
Is it possible you could share a copy of the doc? You are on the right track, but there was a mistake in capturing the formula. The “cip” for the table.column should be a single chip like this:
Regards
Piet
