Counting Decimal Places
Hey all,
Pretty simple one here - is there a formula I can use to count the number of decimal places?
Use case:
I run a project management table, the parent - child 1 - child 2 - child 3 relationship is based on decimals.
I.e.
Parent = 1
Child 1 = 1.1
Child 2 = 1.11
Child 3 = 1.111
If there was a second child 2 for example it would become 1.12.
Thanks in advance!
something like this @Danny_Pettiona :
Best, christiaan
Legend thanks Christiaan
Hey, @Christiaan_Huizer and @Danny_Pettiona
Correct me if I’m wrong but I don’t think that formula works for every case.
This is how I would extract the trailing zeros to get the right number
hi @Breno_Nunes
thanks for jumping in!
you are right, the moment you consider a zero as an option between other numbers, your solution is the way to go. In my understanding that was not the set up, but in case I am mistaken, your suggestion is indeed an improvement!
cheers, christiaan
