Hi, Is it possible to have a table with a top Header and sub-headers underneath? I am trying to find a way but doesn’t seem to be possible?
Something like this:
Thank you very much.
Dear @Daniel_Vianna,
There is an option to group on top of your table as in the example in this link.
I would recommend to create a view of your main table and play with the grouping options in this view till you get the result you are aiming for.
I’d like to re-open this one, because I don’t think grouping covers the use cases that I find myself in. Thread necro to see if there are others in my boat! If this gets Coda attention I’m happy to provide some example use cases.
Although I agree that it looks different depending on the software used, generally I can make Coda look the way I want to present my information.
Based on the sample above, I can produce the following output - and it can probably be adapted for different scenarios. Perhaps sharing what you are trying to accomplish will inspire someone in the community to help you in the right direction.
