Hi there, have been exploring options in Coda for the last few days and have come across a scenario I’d liked to see supported. Apologies if this is a repeat topic.
The scenario in question is around filtering of Cross Doc data. It seems like its currently possible to create a filtered Table view in a Doc A and then sync that entire filtered view to Doc B.
Thats all good and very useful in a lot of scenarios, but I’d love to be able to apply a filter on the Sync itself, so that it can reference data via Formula from Doc B when getting data from Doc A. This would open up easy ways to do [Me] type filtering with the User() Formula value for instance.
If there is a way to do this, I’m all ears ![]()
