Cross Doc Issue?
Hi All,
I have a Cross Doc that I have created so I can share only specific info of a particular doc with a vendor.
After creating the Cross Doc I have hidden two columns in the original table.
The fields I have hidden are still visible within the Cross Doc. I believe the content of the two fields are no longer visible though.
Also, the Cross Doc does not seem to update unless you open it and refresh the content (press refresh).
Is this behavior normal?
Cheers,
Sean.
Dear @Sean_Wood2,
If the “Cross Doc” issue is still valid, it might be the best to get in touch with the Codan’s at support@coda.io
Of course if you get valuable input, it's always great to brief a summary so future users that come across issues can evaluate your feedback.
