Hello all,
I am new to Coda and I’m trying to figure out how to be able to use “CurrentValue” as seen in FormulaMap
, i.e.:
=List("Dog", "Cat").FormulaMap(Upper(CurrentValue))
I was able to use it when applying FormulaMap
to a specific piece of data, e.g.:
=List("Dog", "Cat").FormulaMap(Upper(CurrentValue + "!"))
which produces “DOG!, CAT!”, as expected.
But now suppose that I have a really long utility formula that I want to be able to apply to different data sets. I don’t want to keep copying and pasting the same utility formula. To use the example formula from above, creating this as a formula (named or not) doesn’t work: =Upper(CurrentValue + "!")
. It says that there is no reference called CurrentValue
I then thought that maybe you need FormulaMap
in order for the language to generate a CurrentValue
reference. However, I am unable to do =FormulaMap(...
because it expects two arguments (the data being operated on, and the formula to be applied). I couldn’t find any way to reference the current data being operated on, e.g. thisData
. (When typing this
, the only option it gave me was actual concrete data like thisDocument
My goal is to be able to, say, give this formula the name yell
=Upper(CurrentValue.ToText() + "!")
And then use it across different data sets like so:
=List("Dog", "Cat").FormulaMap(yell)
=List("Whale", "Dolphin").FormulaMap(yell)
Note that I am having the same problem with Filter
. I can’t seem to define a simple filter formula like so, to be used on various tables:
=Filter(CurrentValue > 1000000 AND CurrentValue < 5000000)
