- Edit - Moving this to Suggestion Box! Let’s get a border option implemented!!!
Hello wonderful community! I have searched and read and gone through all the menus, and hoping I am missing something obvious (again lol)
In the Detail view specifically, the title/label of a field is not always clear, especially when a section is in table format. In fact it often doesn’t even seem to be a part of the same field, and oddly appears to almost be a smaller size than the rest of the field. In this example the label for Location Info even seems to be part of the section above it!
Single info fields when stacked next to each other aren’t too bad, but even they could benefit from being larger or a different colour or something.
Perhaps being able to place borders around fields/groups of fields could make a huge difference to this? As you can see, simply adding a quick thin border makes this MUCH clearer.
So, amazing Coda folks…what can I do now with the options available to make this work better? Thanks!
