Would like a formula called Display() that performs last second conversion of my data for display purposes.
Uses:
- When I want to change what column is the display column when selecting from a lookup (e.g.
[Other Table].Display([Different Display Column]) - When I want a select list to show one thing, while being accessible as an object. E.g.
A select list called [MyDropdown] with selectable options defined as[People].Display([First Name])
Using [MyDropdown] in the formula [Full Name]:Join(" ", MyList.[First Name], MyList.[Last Name])← Notice that this must mean that I am accessing the People row in order for me to be able to use both the First Name and Last Name column - Perform some last second computation in a dropdown. E.g. a column [Next Meeting] with this formula
[Events].Display([Start Time] - Now('minutes"))but which can still be used in a formula like [Duration] =[Next Meeting].End - [Next Meeting].Start
@Connor_McCormick1 finish this up
