We have been using Coda for some time, and lacked this feature of Section Access Control. However, if the Secion can’t be edited by several users, but can still be viewed by everybody, it seems a bit useless.
So, what about this new feature? Will Doc Locking funtion imply only edit-limits?
This is definitely something that’s been discussed. It is a common request and we can definitely see use-cases for it.
@BenLee +1 for ability to hide section! Easy to implement and lots of value.
+1 for this. We really need to hide sensitive data in certain views (which we can do but obviously completely useless if they can just view the “Main” table with all the data in).
Awesome, thanks - can’t come soon enough for our team. Google sheets just isn’t up to the task (and doesn’t look half as pleasant as coda
