Allow for exporting docs and tables to word and excel! More seamless integration between coda and more traditional tools.
@Courtney_Milligan1 has the Excel export pack! She can give you more details
Hi @Nur_A! As @Scott_Collier-Weir mentioned (thanks Scott!), I have made an Export Tables Pack which allows you to export your tables to Excel with a button in Coda. Let me know if that works for you!
Also, the latest version of Word will open PDFs, so if you export to PDF from Coda you can then open in Word. Conversion of formatting is sub-optimal, but should still be feasible for at least some use cases.
