Hi!
It seems that the Dropbox pack is not working anymore. It says “This pack has been removed and is no longer available”, it also says that it’s an outdated version.
Is this temporary until the pack is updated?
Hi!
Hi @Karine_Robert, are you still seeing this issue? There was a temporary issue but it should be working now.
Hi @Karine_Robert, if you remove and re-add the Dropbox pack it will work for you now. We fixed an issue with it on our end. Thanks! Sorry for the inconvenience.
Thank you! It’s working fine now!
