Enhancement request - Search should return to same row
After a search result returns nothing, the tabular view jumps to the beginning of the document. It would be better if it remained where it was when we pressed search so that we don’t lose our place. This is arguably a bug.
Agreed here. Also, when you expand a row in a table to the modal view, your scroll will return to your last selected row on exit (not necessarily the row you just expanded). As I’m inputting extra data not in the main table, I want to be returned to the row I expanded in the place I expanded it so that I do not lose my place.
