SureKT
November 17, 2021, 5:16pm
1
Hi! I heard that I should ping @mallika for urgent bugs, I think mine is.
I have some formulas way too to handle in the standard formula editor, so really need the expanded one, but since this morning, this is how it looks:
I don’t know how to solve it, maybe it’s a problem with my resolution or browser, is someone else having the same issue?
Laptop with 1920x1080 resolution
Browser OperaGX
The coda page is not zoomed in
Pch
November 17, 2021, 5:57pm
2
Apparently, it’s a somewhat “general” bug @SureKT !
The pop-out formula editor is not rendering correctly. This problem is recurring across separate Chrome environments so it’s not an issue of resources not fully loading.
As you can see below, the top portion of the editor doesn’t display enough space. This issue began appearing for me some time in the last ~10-20 minutes. Things were working fine prior to that.
[Screen Recording 2021-11-16 at 05.11.00 PM]
… which should be fixed tomorrow
Hi Christian, thanks for reaching out!
We have a fix ready for this issue, it should go live tomorrow morning.
I will make sure to let you know once the fix goes live.
Cheers!
Jesus.
SureKT
November 17, 2021, 6:17pm
3
Thanks! Sorry I didn’t search for the bug before posting
Firefox user here, I still have this issue.
Pch
November 21, 2021, 11:10am
6
Hi @M_Schneider !
Did you try to hard refresh your tab/window (as it seemed to help on Chrome) ?
Thanks! For anyone still stuck, a hard refresh does the trick.
Hi @Pch ,
yes of course, I also rebooted my PC, but the issue remains.
Pch
November 22, 2021, 10:20am
8
Ah !
I’m really sorry to read that …
Sadly, I can only recommend you to contact the support through Intercom (by clicking on the big bold question mark (? ) at the bottom right of your screen) to report it .
Maybe you could use Chrome while waiting for a fix .
Thank you @Pch , it’s working again since today.
Pch
November 24, 2021, 12:25pm
10
That’s wonderful news @M_Schneider !!!
All the merits go to our Dear Codans though !
system
Closed
November 27, 2021, 12:26pm
11
