We haven’t built a full in-doc exporter yet but here’s a quick trick if you want to export your doc to PDF.
I’ve used the PDF option quite a few times now. It works just fine. Thanks.
But you get undesirable headers/footers when you do that - it is fine for internal use but not something you would want to post publicly or share with a client.
I agree with you. I have been using it for internal purposes (quick and dirty) only. For something beyond that, we need something more refined.
Would love to be able to print the custom invoice layout. I hope full fledged printing is high on the priority list.
Yep, agree that we need a more complete solution for proper export, it’s on our list!
Hi there! When I try to print the Coda Doc with the method above, the thing right aligned disapear
I tried to print a (pretty large) coda doc this morning, on my Mac using Chrome, and I get a PDF with garbish.
I tried to print to PDF from Chrome or directly from the Apple print interface with the same results.
What’s wrong ?
I’m experiencing the same
I want to export to HTML.
Bcz, HTML is the best compatibility, and Coda is build by HTML, include CSS, JS.
Outline , bullet list, color, font, bold, link, photo, table , chart.
if all is right , and then batch convert PDF .
When I print photos, it currently looks like this.
The original looks like:
Will there be an adjustment here?
Is there a way to make a second column?
Very soon I hope.
I’ve spent a year deciding on Coda or Notion
Full doc export would be brilliant.
Dear @lane,
On a regular base I get questions from people that like Coda a lot, but want to be able to export at least some tables, even while knowing that the information becomes static.
I know very well that it’s more a psychical thing that people feel that they are locked in
Would it be possible to provide a tool/wiki to export one table a time to the *.csv format?
It could come handy for the static information, like contact details or calculated results that do not change anymore because they are based on historical information
I am aware that “copy/paste” it’s possible, but
- often it are the details that make people deciding to go for it or not!
Keep up with the great work
Yes, agree we should support this, just have not prioritized it yet. In fact, we prototyped it a while back. It’s not on our immediate roadmap, but thanks for re-upping this one, I’ll add it to our stack to prioritize in coming quarters.
im having the same issues. would be great to have alle the picture as an attachement or something.
bin auch auf dem bau tätig ;-).
also markup on pictures would be great.
